B.autry4711A
Thread starter- Joined
- Feb 24, 2005
- 176
Hello,<br /><br />I have a question. When you run your boat at idle it gets hot on the heads but if you raise the RPM's but not over 1500 rpm's it is cool. What I mean is I can hold my fingers on the heads for a few seconds say about 3 to 4 seconds at idle before I have to remove them, but at higher RPM's I can leave my fingers on the heads all day seems like. Is this normal? I think I know the answer but want to see what you guys the experts think. Yes, I did run this while the boat is on the trailer with the water muffs on the motor at full water hose pressure and it peed a good stream of water out of the tale-tale.
