1989 Stratos 201 pro HP Recomedations
mav6759
I just got a 1989 stratos 201 pro that I know nothing about..From what I understand it 20.2 feet long.. I'm not use to a boat this big,,I'm use to 16 to 18ft boat with a max hp of 90hp..I was wondering what's the least and max hp I can put on this boat..I'm not looking to go very fast..I want to stay around 45 to 50 mph max, but I do have to get the phone on plane..does anyone have any ideas..
Sea Rider
Re: 1989 Stratos 201 pro HP Recomedations
Probably there must be a tech plate somewhere transom that specifies max HP engine for that boat model. If not, contact manufacturer and ask . BTW, 50 mph is a fast speed, probably not achievable with that size boat, unless you install a big and powerfull engine.
Happy Boating
82rude
not sure of max hp rating but ive seen several on line with 200 hp motors and one in a forum with 2.5 litre merc that did 75 mph.the new stratos elite of the same size as yours has a max rating of 300 hp.
boobie
Find the max hp rating and we can tell you more.
mav6759
The max plate says 235hp max,,I just need enough motor to get this boat on plane,,with about 2 people and equipment..I don't need to go fast..
82rude
you don't want to severly under power either ,you will hate it .200hp would be min if I owned it .ive seen at least a dozen on line all with 200 hp .is this a good solid boat that you would like to keep for a time?pictures are always welcome .bet you that boat would rock with a 225 h.o. etec on the back.
boobie
A 175 hp would probably work out just fine on it.
Yep, that's probably about the smallest I'd try too. It's possible a 150 could work for you, but most 150's have the same displacement and weigh about the same as a 175, so you may as well go with a 175 if you can find one.
(Now if it were my boat I'd be wanting every last bit of HP I could put on it, but I perfectly understand those who are more sane than myself - unfortunately I've learned all too well that it costs $$$$ to go fast).
