1989 Regal 4.3 engine quits after couple minutes
snowsdog
I have a 1989 regal sebring 195xl with a 4.3L I/O Merc. Driving it for about three to five minutes it blows the ignition breaker and dies. After turning the key off you can reset the breaker, however as soon as you turn the key to the on position ( not the start position) the breaker will trip. After it sits for a couple hours it will start and do the same thing? Suggestions on where I shoudl start.
It has a mechanical fuel pump, and a friend said could be the alternator getting hot and shorting?
any help would be great!
Thanks,
kurt
gcboat
Re: 1989 Regal 4.3 engine quits after couple minutes
So, how long has this been going on? Have you done anything to the motor?
Added anything electrical to the boat?
If nothing else but for peace of mind pull the alternator off and have it bench tested. Also check that big ground wire going into the engine block. Make sure it is good and tight. Might take it off and clean it good while there.
Could also be the reset button is going bad. It has been known to happen - not very common though.
snowsdog
No electronic add ons and no motor work, just started doing this a couple weeks ago.
I will check the ground and clean it.
thanks,
Kurt
