Re: 1989 omc 5.8 bayliner turn key to on and temp gauge jumps to hot?
Disconnect the wire off the temp sender on the engine and see if the problem still exists. If the sender is shorted to ground, that is what will happen.
With the wire disconnected from the sender the gauge still pegs full, disconnect the sender wire from the gauge, if it still does it, replace the gauge.
