Re: 1989 Mercury 35HP
The only time you change jets in a carb is to compensate for running at higher elevations. Just changing them for more power doesn't work that way. Make sure the boat is loaded evenly, the motor mounted properly, and you are turning the proper RPMs at WOT.
