Beachrights
Thread starter- Joined
- Jul 17, 2007
- 17
At just above idle 1000-2000 rpm it misses stalls and shakes.
I have -changed all fuel filters, water filter, plugs, wires, accelerator pump and cleaned carb as best as I could. Put multiple carb cleaners, seafoam into tank and carb to no avail.
I can get the timing to have it run good at idle but when you try to throttle it bogs and dies. I can also get the timing and mixture somewhat right to make it run crappy at best but I am getting pinging at high rpm so that will not work! I can not find a happy medium.
Would the anti-syphon [spelling?] valve be causing this? It runs fine at 1/2 throttle and WOT. Ithink I am looking at a fuel or air problem but I can not find the issue and I am tired of spending money only to find I have the same problem.
