Re: 1989 Johnson150 Comp Test Results
Hi DHadley,
The numbers stamped on the heads are, portside=328324, stbside=328557. So unless the first three are the key, they are not the same. What does this imply/mean?
Hi emdsapmgr,
You suggested what I basically did (I think). I ran the motor with the fuel line from a separate 5 gallon premixed container and left the main oiler line connected. After about 4 gallons was used, the main oil tank did not look as though any oil had been used. If I understand correctly the mix from the vro is going to be more like 100:1 at idle so a visual of oil burn may not be possible. I see your point.
Could someone tell me what this black goo means? As mentioned it ran on hose for 4 gallons worth of fuel yesterday and when I went out this morning, this wonderful stuff was oozing out.
http://picasaweb.google.com/lh/photo/BImfL0_erR5ek6EEilAvpTPMFGspHqGFO_myBYDLSys?feat=directlink
Hi DHadley,
Hi emdsapmgr,
