MASTER Brian
Thread starter- Joined
- Mar 26, 2006
- 738
I am looking at buying a 1989 Ranger 363V 18' fish/ski boat that has this motor on it.<br /><br />Is this a good motor for this size/type boat?<br /><br />What compression should this motor have and what is the best way to check compression on these motors? When I check compression on 2 stroke jetski's the plugs need to be grounded to the block so that you don't fry the coil, is that the same for these motors as well? I don't want to fry anything, especially before I buy. <br /><br />I'm also curious what spark plug this takes or what the plug size is, so that I can make certain I have the correct adapter for my compression tester on hand when I go to look at the boat.<br /><br />Are there any other things to check for when looking this motor over? I've been told that these motors sometimes had issues, because the rings were too high on the pistons, any truth to this? This is why I want to run a compression test.<br /><br />Thanks for any info...
