1989 Johnson outboard
mrmrxman
I have 1989 Johnson outboard started it up one time an now it will not start.Got gas going to it got spark to plugs,just will not start.It is tiller motor ,pull rope to start it.I can pull the rope all day it will not start
boobie
Squirt some premix gas in the carb throat once and see what happens.
mrmrxman
I put gas in the carb nothing .I can pull that rope till I am blue in the face.
Honorary Supreme Mariner
???-----What horse power is the motor ??-------Have you checked for water in the fuel ?--------Have you checked for strong spark at plug leads?--------When did this happen , suddenly or slowly got harder to start ?------How long have you owned it ?--------Questions need to be answered so you can be pointed in the right direction to sort this out !!
mrmrxman
Johnson 15 hp, no water in fuel I just filled the tank up at gas station.I would say spark not to strong.. It happen suddenly I just got this motor an started it up an it started on the third pull ,then I shut it off an tried start it again.An it would not start you can pull that rope all day.
60sboater
Starting fluid is considered a no-no but the Walmart brand has top cylinder lubricant so it may not wipe oil film off cylinder walls,causing damage to them. Even experienced mechs will sometimes use it (very sparingly) because it is so good at t-shooting. If it fires at all on s.f.,the engine at least has some spark firing the plugs. Check the basics as advised above. The sticky has much helpful info in it. Good luck...from this iboats noob!
