1989 Johnson GT150 outboard
dwblank1949
My motor will not run or idle without my primer lever is on prime! It acts like it runs out of fuel when the primer lever is in the run position. If I choke it at the key switch it will run! When I stop using the choke it just dies.. I replaced the VRO2 pump and plush limiter. HELP
dwblank1949
You were right. the idle circuit was clogged on all three carbs. Thanks for ending my nightmare!
