If the motor runs great now don't mess with them. Keep reading though...
What you should do now:
1. Change lower unit fluid. If it looks milky or has water in it plan on re-sealing. When you do change it replace the little washers on the drain and vent plugs. Make sure you pick the old ones out. Grease the splines on the prop shaft while your at it. Any grease is good, BRP triple guard is best. Yep, I said it.
op2:
2. Stabilize the fuel. Startron by Starbright or BRP 2+4 seems to work best these days, I would think they sell all these products right here on this web site. I said it and have just started a very active thread for you.:lol:
op2:
3. If it still has the VRO hooked up do NOT run it out of fuel, that will just fill the bowls with oil and then you will have to clean the carbs. If it runs pre-mix go ahead and run it dry. Either way fog it before you shut it off. Once again BRP makes a decent fogging oil. They also used to recommend a fuel mixture that had 2+4 and Fogging oil and such in it but if you only have one motor to do cost would be prohibitive. Ask and I'll post the formula. ( wouldn't want this thread to get too active, haha)
4. Grease. should be at least two grease zirks, maybe three.
5. Lightly lube the bendix.
6. Change impeller in the spring before start up. Inspect water pump housing and replace if you see wear in the cup or on the base plate.
7. Inspect all fuel lines, internal and external. I would recommend replacing every one so you know where your at, many people don't bother but old ones can cause problems up to and including catastrophic failure if they lead to a lean condition in a carb.
7. New spark plugs in the spring after initial start up.
Others will chime in and tell you I am crazy. This will work. Sorry about all the replies you will now get.
