spdjnky_42
Thread starter- Joined
- May 16, 2010
- 11
Just wanted to say thank you guys for the help previously
I recently bought a 90 hp Johnson titled in 1989. Compression tested good, motor ran good the first day. On day one it would gurgle at 1/4 throttle then come out of it with more throttle and run great. I assumed either just a 2 stroke thing with a v4 or its a little cold here right now (50*F) Then after it warmed up it still did it so I figured normal or low throttle jet issue. Yesterday I was running it and after about 5 minutes WOT it lost 500 rpm and kinda sounded like it was out of fuel then continued to run at 5000 rpm, 1st day it ran 5400rpm. After checking ball was pumped and tank still had new fuel. Now keep in mind this is a jet drive now. So maybe it had something in the shoe. IDK havent drove it again. After backing up and pulling on the boat seemed like maybe it was just something on the shoe. Ill let you know in a few days of the issue condition. I did notice that the left intake hose was spraying a fine mist so is it possible it was getting water in the cylinder? Ill get that fixed and report back. My main question right now is if I need to pull the carbs what does it take to bump this thing to a 115 or 140? Just 115/140 carbs and exhaust manifold along with maybe honing out the intake slightly? Is this a fairly easy job for someone with mechanical skills? Finally what year parts are interchangeable? Sorry for the long post TIA
