Hi All<br /><br /> I have a few questions, I am a new boat owner, here goes, I have been in here and read alot, Thanks to all who post. I have a 1989 70HP Johnson, Ok 1st question, When I come back from the lake and tilt my motor up for towing, i have about a 3 to 4 min span, where i leak fuel. It will leak and then stop, It comes from the bottom of the black plastic carb cover, Is this the excess fuel that is left in carbs ? Ok 2nd question, this weekend i changed my lower unit oil, it came out but it had a tad of white in it, the oil was brownish, but with a very small kinda like a swirl of white, not alot of white , i would say 80-20 mixture, Lower unit looks tight and not damage to it, Is it a prop seal ? Is that something a avg type guy can fix ? .. Last question, How much would you have to run a motor without having to winterize it ? if i ran it a good hour or so during thw winter months would that be ok ? Thanks for any and all help in advance. Sincerly, Brian
