G'day all I have a 1989 Johnson 60 hp on a 20' pontoon that has a problem with missing at higher rpms Just purchased unit so I don't know any history on it Motor will run fine up to 3800 rpm then start to miss the more throttle I give the worse it sounds Can not get it above 4400rpm to get it to rev that high is hit and miss sometimes it will go that high other times won't go past 4000 Tried using tank from diff boat with no change ,have checked compression its 120 on all 3 cylinders ,installed new plugs,have a spark tester and opened it to 1/2 inch still gets good spark on all 3 cylinders , runs the same if motor is hot or cold my next step will be to rebuild the carbs unless someone has a better idea Any help would be appreciated
