1989 Johnson 30 HP outboard (australia)
scott82
hi all
is it hard to change the water pump on a johnson tiller outboard?
Cofe
Re: 1989 Johnson 30 HP outboard (australia)
It should not be hard to do. The drive shaft on some motors gets rusted in the spline connection in the power head. If it is not rusted, it is simple to do.
I would recommend getting a whole water pump kit if you decide to do it.
scott82
thanks cofe
scott82
do you have any pictures/diagrams ???
Cofe
Scott, here is a procedure.
There should be 4 bolts, and 1 nut/washer holding on the lower unit. Remove the nut/washer first, unscrew the remaining 4 bolts equally, but leave them hanging in the threads a little bit.
Then remove the water intake screens, and unscrew the two brass fittings on the shift rod, turning only the upper one because if the lower half is turned the shift linkage length could be changed.
Then use a pair of needle nose pliers and slide the upper brass fitting up the shift rod. Next carefully remove the plastic ferule that was underneath the brass fitting. The keeper has a vertical slit, use a finger nail or small screwdriver to open the slit, and remove. Shift the gearshift in forward position. The upper brass nut should be then removable. Lower the lower unit slowly. The drive shaft slides out on its splines. Good Luck
