1989 johnson 175 power tilt and trim
rippinnt3rrin
I have a 1989 Johnson 175. the power tilt and trim seems to have crapped out. I also have a Johnson 175 fast fast strike that has a bad power head that was give to me. my question is..... will the tilt and trim system from the fast strike fit on the 1989 175?
AEROCOOK
Master Chief Petty Officer
What year is the Fast Strike?
In regard to the one on the 1989 motor, define "Crapped out". Just wondering it there's an easy fix.
rippinnt3rrin
I think its around a 1998 fast strike. Im not sure if its an "easy fix" or not until I dig into it. I checked everything before I left the house. (trimmed up/down, cranked the motor) Then got to the boat ramp and the trim wasn't working. Im getting power to the motor but nothing is happening. You can hear and feel a "clicking" in the motor like its locked up. If its just the motor is bad that's easy enough to get another and swap out. But if its a more "advanced problem" Im just wondering if the power tilt trim system swap would/could be an option.
emdsapmgr
Your 89 V6 is a crossflow engine. The Faststrike is a newer looper V6 model. Not sure just what the compatibility is between these two completely different engines. Maybe an expert will know.
racso
trim and tilt and motor are two different things no, i think if you have all control cables you can make it work,, by the way i have a trim and tilt motor that am trying to put in my 87 evenrude but the fluid reservoir is cracked any one know where can i get one
