mark's Mobile marine
Thread starter- Joined
- May 14, 2017
- 6
I am working on a friends 1989 johnson 150 xp. After he bought the boat we had intermittent no start issues. Turned out to be a bad trigger. Replaced with CDI trigger and replaced power pack with CDI one. Motor runs good, Good Idle, Nice WOT. but he has to push in on choke to get her out of the hole and on to plane. Of course i have clean carbs. we switched to Premix and remove VRO pump. Last year we tore down the motor AND replaced all gaskets and cylinders look good. Compression is 95 - 100 psi on all cylinders. did all the sync and link. Everything seems find but still need to choke to get on plane. is it possible i need to change the jet size? we are at 500ft over sea level. problem has been consistant since he bought it ever after repairs and adjustments.
Any ideas?
Any ideas?
