1989 Johnson 140: RPMS will not reach higher than 2300- Help Please
tj32046
Replaced all coils Checked timing ,compression good ,Motor revs good out of water when under a load in water will not turn up no more than 2300 rpms !!!
jakedaawg
Has the boat ever run goof for you or is this a new to you boat and motor?
tj32046
Compression good on all 4 cl it's twins 1 runs good the other is the problem child & yes it runs good under no load & the boat is new to me carbs been rebuilt before i got in oct..
Honorary Supreme Mariner
???---Runs good with no load ????--Most motors sound good running on a hose and that means very little.---Have you looked into issues with crankcase compression / seal rings on the crank ?
tblshur
use good insulated gloves and or pliers to pull each spark wire off, and each one should drop the rpm slightly if one or two does not decrease the rpms then they are not firing correctly.hope this helps:joyous:
