I have a 1989 120hp Johnson outboard with VRO. The temp. gage will move from the lower Green position to the red position within 5 min. of running at 4500-5000rpm with NO over heat warning horn. The engine feels pretty warm but not hot, and the pee stream is good and strong also warm but not hot.A friend who is also my boat mechanic replaced the water pump and thermostats,still get the same results.Tested the overheat warning horn on both sides and they are working,also the S L O W system is working. Do I trust the gage or the overheat warning horn or what?Could the temp. sensor be bad in the temp. gage?Any ideas will be appreciated.
Thanks.
Thanks.
