Hi guys,
I need some advise on a 1989 120HP Johnson Outboard.After running at 4200RPM for about 15 min I start to loose power and the engine surges and then stalls.I live on a saltwater creek and it takes about 15 min to get to the sound where the water is usually more choppy.The stalling occurs about the same time and location, I.E after 15 min run time AND just when I enter a choppy sea.I opened the fuel fill cap to see if I had a vent restriction but the engine still stalled. When I disconnect the fuel line from my aluminum below deck fuel tank and connect it to a 6 Gal portable tank the engine runs fine...no stalling or surging.Back at the dock I disconnected the fuel line from the below deck tank and pumped fuel into a mason jar to look for water.Minimal water and some trash.Fuel flow from hand pumping was good ..no apparent restriction or massive amounts of water or trash. Any ideas? I appreciate any thoughts on how to test my fuel/air supply system.
Thanks.
Ajahman.
Thanks.
Ajahman.
