1989 johnson 120 low hp
jh2275
Thanks to anyone who has some advice. I have a 89 johnson 120 90 degree looper. Got the motor from my brother. It ran a little rough at idle and the power pack was bad. Changed pack and cleaned the carbs. This motor was on a 19 1/2 gambler intimidator. I put it on a hydrasport x260. That's a 16 1/2 foot. The gambler would gps about 46-47. On my boat I'm running 42-43. I did have a 70 hp johnson on my x260 and would run 37. The performance difference feels like I gained maybe 10 hp. I'm lost. Any ideas?
jh2275
Compression 124 on all four cylinders. Found one coil had a weak spark changed it. Idle is low. Tried to adjust idle screw under the flywheel. And you can see timer base move but rpm does not change at all.
flyingscott
Double check to make sure that screw is not the timing stop. Get a manual and do a link and sync also do a cylinder drop test
jh2275
I've done a drop test it's fine. It's not the timer advance stop it's on the other side of the motor. I looked it up and it's supposed to be a idle adjuster. Motor still has a miss at idle and at low rpm. I want to look in the direction of a timing issue but I'm just guessing. Haven't worked a lot on outboards so the lync and sync I'm clueless. I will have to research it some. Forgot to mention the motor had no issues before the power pack went out and we swaped it over to my boat.
flyingscott
Was it a new powerpak and make sure all the connectors are tight. Sometimes the pins in the plugs will push out and not make a great connection. Make sure all the carbs are opening and all the throttle connections are working. Also what RPMs are you running at WOT
jh2275
It's a new pack. Checked all the connections twice. All the carbs are opening and throttle connections are tight. I've tried 3 different props. 19-20-23 pitch. Running 5200 wot on all 3. Mph goes up or down maybe 1-2 mph between props. The fact that going from a 19 to a 23 pitch doesn't change mph or rpm at wot is confusing to me.
flyingscott
Try a different tach and are you getting speed off of gps or a speedometer. Can you turn the flywheel by hand easily. Maybe time to go to the dealer and get a leak down test done.
jh2275
Got another tach at home. I will swap them and see. Getting speed off of gps. I've heard of bad timer bases and stators causing fire to basically cut out on cylinders after a couple thousand rpm's. Possible maybe? Could the timing be off and that could cause it's rough running at low rpm and maybe not open all the way up at wot?
