1989 Johnson 120 - Engine Forward / Reverse not shifting
djwixted
I have a 1989 Johnson 120. started, stalled, would not shift into forward nor reverse, like the single handle shifter was stuck.
replaced cables with new, adjusted to neutral. Removed shifter assembly without cables and mounted the shifter control box onto a stationary sheet of plywood and the shifter moves easily, settles in neutral easily, handle ops out for neutral start position. Reinstalled in boat with new cable.
cables and shifter move freely/easily when not connected to engine levers.
once cables are connected to engine, running or not, engine levers will not move.
I appreciate any ideas. Thank you.
djwixted
I was able to "pry" the reverse alittle bit when initially trying to test throttle position / cables / control box.
Did not try to budge them since I reinstalled everything.
Should they swing freely, or with a little force?
Thank you very much.
interalian
Throttle arm should move very easily. Gear shift should be easy but a little 'notchy', but always do it with the motor running, or turn the prop while you try to shift.
djwixted
Just for clarity, -
run the engine;
with cable disengaged, try to move the shift levers on the engine?
djwixted
...or alternatively, with the engone off and cables disengaged,
turn the prop and try to move the shift levers on the engine?
