I am a new, first boat owner. I recently bought a 1990 Bomber 17.5' fish and ski with a 1989 Johnson 110hp motor. I got these numbers off of an aluminum circle on the engine: 185393 26KL 1 R7490919.<br /><br /> When the motor is cold I can pump the bulb on the fuel line once or twice, raise the choke lever to the full up position, push in the key and immedialetly turn it to start the motor. It starts on the first or second crank every time, when it's cold. It puts out a bunch of white smoke for a few seconds and the RPMs race up to a very high level within 10-15 seconds. At that point I push the choke lever down and it idles nicely. The enigne delivers excellent power and runs rather smoothly. It might sound a little rough at low RPM but, my inexperience means I don't really know what "a little rough" vs. "smooth" is for the engine. <br /><br /> Here's the problem... If the engine runs for even just a few minutes (3-7), just enough to get it warm, it won't restart. Better said- I can't get it to restart. (I don't have the manual and it doesn't look like iboats.com carries a manual that covers my engine.) Does this sound like a problem anyone recognizes? Is there some sort of warm restart porcedure? If so, how do I fix it?<br /><br /> Another question- there is a small red lever/knob on a cylindrical component about the size of a D cell battery on the top of the motor directly above where it is clamped onto the transom. When I pump the bulb on the fuel line until it's tight and then turn that red knob/lever to 1/2 its full throw I can hear the pressure I built up in the fuel system release. What is the component, what does it do, and what does the red lever/knob adjust? When should I mess with it?<br /><br /> Any help will be highly appreciated.<br /><br /> FYI: I do have some experience with and knowledge of small 2-stroke engines.<br /><br /> Thanks.
