1989 johnson 110 motor what part do i order,,Help...
Dozer45
I have a 1989 johnson 110 motor and i just got from a guy. Its takes about 20 minutes to start but once it does it sounds good. Now with the engine running and you give it gas still not in gear this roller sticks forward . Then when i cut the gas off back to neutral it still wants to idle real high until i push this black roller thing back. Im new to this boat engine thing . I got the manual and would love to learn how to fix this problem. I think im missing a part. On the upper cam there is no bushing could this be the problem ? I cant find what part i need on the diaphragm i and a bushing just dosnt look like it would fit.
jakedaawg
I think you will need to go ta a marine salvage to find those parts. Pretty sure they are NLA
emdsapmgr
That upper carb roller is a common failure item on these crossflows. The skin of the roller is a sort of clear plastic, which discolors from the gas/oil and eventually peels off. The center of the roller looks like it's also fallen off. So, you need a new upper carb roller and sleeve. Part number 432639 and the retaining "o" ring, part number 324678. Both are still well stocked at all Bombardier factory warehouses. See your local dealer to get them on order. In the future, you can look up your own part numbers on the factory exploded parts diagrams at this website: epc,brp.com
