1989 intruder alarm help
Shrapmetal
I was recently given a 1989 ranger with a evinrude 150 intruder. We I first got it I turned the key and the alarm would sound constant with out trying to start. The next day I went out and it chirped like it is supposed to. I did nothing to it. I took it to a mechanic had a carb rebuild new impeller and something replaced with the oil system. It had sat 2 years. They ran it for half an hour no problems. They started it for me chirp no issues. Week later I'm ready to get out on the water. I try starting it day before and alarm sounds constantly at the turn of the key. Before starting. Started fine first time. Alarm stayed on. I read some stuff about disconnecting the beige wires at the heads. Alarm still constant. I disconnect the one on the lower port side that I believe goes to the oil tank and it chirps like it should. Oil bulb seems full. When the motor running little blue smoke that I would expect from a two stroke. I pulled the sensor/intake filter clean there looks like a black float that looks like it may slide up and down but doesn't move. Oil tank 3/4 full. Help I want to go fishing tomorrow!
Joe Reeves
(Odd Soundings Of Warning Horn)
(J. Reeves)
Should the warning horn beep constantly when the key is turned to the ON position rather than sounding just a short beep as it should, do the following test.
Remove the TAN wire from the horn. If the constant beeping continues, the horn is faulty, in which case replace it. However, on the other hand, if the beeping stops, something has gone wrong with one of the sensor components at the engine, in which case start disconnecting the TAN wires that are connected to the various components (Heat Sensors, VRO, Vacuum Switch if so equipped, Oil Tank). Disconnecting a unit and having the beeping stop...... you've found the faulty component.
NOTE: The small black plastic horn that has a built in black ground wire...... The TAN wire must be attached to the terminal closest to that black wire. Otherwise weird things will happen.
grtomboy
I just read something about the sensor on the bottom of the oil tank being loose? Magnet mount causing inconsistent alarms?
Shrapmetal
Seems to work fine when I disconnect the wire to the oil tank. Still chirps when key is turned on. The constant beep is gone.
flyingscott
If the sensor in the tank is bad there are 2 things you can do. Disconnect it and leave it and make sure the tank is full all the time. Or replace the sending unit completely. If you took the sending unit out of the tank I would bleed the system just to make sure no air is in the line. I believe your motor is newer than than the boat because the intruder should be a looper motor and those did not come out until the 90s. Need a Model #
