1989 Force Trim & Tilt
BJudd
Hi all,<br />Just wanted to see if anyone can help me with the following problem that I've got. I just replaced the valve body to my 1989 Force 125 hp trim & tilt hydraulic pump. I had a slow leak down & had the valve body replaced. I got everything back together & the motor goes up & down great. The problem that I have is that now when I hit the up button to lift the motor it goes down. When I hit the down button it goes up. Something got reversed some how & I can't figure it out. I didn't touch anything on the trim & tilt control switch. There is only one button on it that reads up & down. I hooked up all of the four hydraulic lines to the exact same spots on the valve body. Anyone have any ideas what the problem may be? At lease I got the trim & tilt to work great again with no leaks!!! :) <br />Thanks,<br />BJudd
