1989 force outboard 85 horse
Charlie Loehnis
i need help<br />having trouble starting without starting fluid-once it is running, she wants to stall when idling.<br />also when running she tends to bogg down when given full throttle and stalls.<br />any help, where do i start<br /><br /> :(
Scottj25
Re: 1989 force outboard 85 horse
Sound like you need a rebuild for the carbs. I've been told using starting fluid in a two cyl. is not a good ideal. You might also check if the fuel screen in cloged and also check the pump blub? making sure that it gets hard when pumping it up. If it stays soft or goes soft after you let go of it, it needs replacement. :D
