1989 force no water coming from the two holles
irinka_85
i took out the impeller looks like some of the corners got bend could be it the reason ?
SweeperForce
Re: 1989 force no water coming from the two holles
Since you already have the lower unit off you might as well replace the impeller. Bent up corners may reduce water flow but I doubt it would stop it all together. Take off the therostat cover and remove the t-stat, you should see two holes, pour some water down the first hole. Water should come out of the relief port(holes on middle of leg). If no water then you have a clog. Hope this helps.
Tom
irinka_85
sorry to ask where is the location of the t-stat? because its my first boat thanks
jerryjerry05
Get a factory manual.Then start looking up parts for your particular motor.Profile?Model @ serial#?
Boats.net has good diagrams for most motors.
Post pics of the impeller and the housing.J
irinka_85
hey i thanks for the help i took the tranny off today and i took a power wash machine and put it itno the tube thats goes into the engine and water still didnt come out of the 2 holes in the leg after i took the power wash and the water came down should i start the engine? or i have a plag some where?
i also added the impeller picture
Robert D
Which engine do you have? On the 1990 Force 150, you get exhaust out the holes in the back of the leg, along with some water spray at higher rpms.
I wouldn't be shoving a pressure washer up the brass pick up tube....doesn't sound good. You say you're not getting water out the holes....I assume you're talking about while the engine is running and warmed up, correct?
jerryjerry05
You might not have enough water pressure on the hose.Get a big trash can and fill it with water. Best place to test is in the lake/ocean/river(profile) on the hose you supply of water is limited.
If the impeller is old while it's out change it.Change it anyway.
Is the shaft seal in the housing OK?
You can do damage with a pressure washer.Too much pressure could push the connecting seal out and you will never get enough water till you remove the powerhead and fix it.
The two holes are for the pressure relief valve.If you motor is operating right and the valve isin't stuck you might not get any water out of there till you reach high RPMs.Most should come out the snout anyway.
Fill out the profile you might be close to someone who can help.J
irinka_85
i have the 1989 85hp force yea i started the engine and on idle there was no water so i guess i will try to fill up big trash can and see on higher rpm
irinka_85
hey i tried today with higher rpm still no water coming out i will try tomorrow to buy a new water pump kit and see if that will help because it feels like there is a pressure from the two holes on the leg
