I have this 1989 85hp force on a stand. It will only crank slowly while the plugs are in. With the plugs out it moves freely by hand and cranks fast. I also noticed that the screw which holds the wire junction strip in gets red hot while cranking! Since it is one the stand I have jumper cables from a working battery to solenoid input and grounded ro case. It doesn’t actually start yet.
To troubleshoot I have:
Removed lower unit to make sure it is not adding resistance (though plugs being removed seems to make it work fine)
Tested power through to the starter. It does not seem to drop significantly.
Pulled solenoid and black ground wire and cleaned them up.
Tried another battery from a working vehicle and charged/ verified original battery.
Pulled starter apart and visually inspected it. It has a couple grooves in the armature which I think are from wires breaking off. Cleaned up and put back in. Same results.
There only seems to be a small ground which runs from the solenoid to a screw by the solenoid in a mounting bracket and then to the wireing junction.
I also tried moving my jumper cable to other spots on the case to make sure I had a good connection.
I am thinking the starter may be shot. I am going to try another one. I also think I may need to replace the ground wire and run a dedicated ground to the battery just in case my jumper cable is somehow bad.
Any other thoughts? I am sure I will have more questions once I get this solved!
Thanks for all of your help and expertise.
Jim
Jim
