First time iboats forum user, lifetime boater!
On the flywheel of my 1989 Force 85 HP, I see 4 timing markings. Three lines close together which I believe are 28, 30 & 32 degree markings. About 2-3 inches to the right of the three lines (as you face the engine from the front) is another single line. At idle, and using a timing light, the single line is just about centered with the timing marker on the block just below the flywheel. Does sound right? The block timing marker is on a casting just below the flywheel, centered on the front of the engine? Just want to be sure I have the right marker!
Also, at WOT, should the 30 degree marker be centered with the block timing marker?
I have the Force manual, which is very helpful, but comes up short on timing issues.
Thank you!
David
Thank you!
David
