1989 Force 50 won’t idle after engine warms up
Wcbond4
507X9C
Just bought this old boat. Engine starts up very easily and will idle, but after getting up to operating temp, it won’t idle. When trouble shooting in the barrel, it also has sluggish throttle response time after being warm. Too much throttle too fast will kill it.
I did some initial diag and found that I wasn’t getting any spark on the top cylinder. Changed plugs and the coil for that cylinder.
Rebuilt fuel pump
New gas and oil in the tank
New battery
Supposedly the carb was rebuilt by the guy I got it from. For the fact that it idles correctly when cold makes me think it’s not a carb issue. The bogging under throttle makes me think it could be though. Possibly these issues are related but maybe not? Could be two different issues. Could my other coil pack be weak and I’m not getting adequate spark after it’s warm?
Any guidance is appreciated.
Honorary Supreme Mariner
Open slow speed mixture screw 1/8th turn at a time and test run.
jerryjerry05
Do the starting fluid test: start the motor, spray SF around the intake side of the engine. If that makes the motor run different?? Then it's sucking air and needs to figure out where?
You have 2 port covers on the intake side. One has the fuel pump the other nothing. Most time the port caver gaskets can blow and the motor sucks air.
One TINY!!!! backfire/ cough/ stutter can blow one of these gaskets.
Wcbond4
Spraying this gasket in the rear killed the engine.
cyclops222
The selling of old, run ito the dirt, boats and engines, with NO maintainance should be illegal !!!
WE kill, destroy useless horses. Why not boats also ??
Wcbond4
Also possible that the port cover is causing it as well. I sprayed all around the gaskets below the fuel pump and it also died then too
kalebsheridan
How'd it turn out? I have basically the same motor so I'd like to know in case this happens to me.
