I noticed there is a ton of slop on the shift arm linkage that connects the lower shift rod to the shift rod arm on my Force 50. The schematics shows a #24 bearing and I'm wondering if this is a nylon hat section that rides over the shifter shaft to keep the hole diameter tight or just a washer that controls only side to side movement. There is enough slop in the connection hole that effects return to neutral when I shift lately.
Thanks
Retrojeep
Thanks
Retrojeep
