httysctty
Thread starter- Joined
- Sep 16, 2010
- 18
So, I tried to start my motor a day after she ran fine and it took a jump from my truck to start her. I ran her for over an hour and I stopped for gas. She would not start after that. She turns over slow, until I take the plugs out and then she cranks really fast. I took apart the carb and it was filled with gas. I sprayed it down with carb cleaner and blew it off with compressed air. Also looks like there is fouling on the plugs, but I hear you can use these plugs forever since they are the kind with no gap... true? The starter is engaging and fuel is not an issue. I have cleaned all terminals and ground on the block. What else should I be looking for? Thanks in advance for you help and direction.
