1989 FORCE 50 HP
viperkid
WANT TO BUY TILT TRIM UNIT,(USED) WANT TO KNOW ACTUAL HORSE POWER AT PROP, ALSO MAX RPM FOR 16FT ALUMINUM, MEDIUM WEIGHT AND STOCK PROP?
roscoe
Re: 1989 FORCE 50 HP
Try ebay for used tilt and trim.<br />Better to buy a new CMC unit like this:<br /><br /> http://www.iboats.com/mall/index.cgi?prod_id=13581&current_category=cmc&cart_id=634081303 <br /><br />Starting with the 50 hp at the powerhead, minus 2-4 hp to get it to the prop, minus the possible 3-5hp from manufacturing variances, you will be down around 41-48hp. Now factor in the age and condition of the motor???<br /><br />You could be somewhere between 35 and 48 actual prop hp. Maybe even as low as 20 hp if it doesn't run worth a crap.<br /><br />Max rpm is for the motor, not the boat. You need to get the correct prop on the motor so that the motor reaches 4700-5500rpm at full throttle.<br /><br />If your rpm are over 5500, then you need to get a prop with more pitch. If the rpm are under 4700 rpm, then you need a prop with less (lower) pitch.<br /><br />Read this info here:<br /><br /> http://www.iboats.com/cgi-bin/ubb/ultimatebb.cgi?ubb=get_topic;f=36;t=000015 <br /><br />And this:<br /><br /> http://www.boat-props.com/prop_rpms.html#1
viperkid
Thank you very much, I've got some checking to do, this is the coolest site on the net for Techs to visit, thanks again, Scott
