1989 Force 35 hp
Low Force
It ran ok at the season start. Now it will not run unless the throttle is open wide. I replugged it on Sat and found the old plugs pretty black. The carb doesn't look too bad. Is this a fuel flow problem caused by the carb? Maybe a problem with sticky linkage? Anyone had any experience with this series of this motor and this problem?
