1989 Force 150
Mike87o5
I’m having some trouble with my outboard. Starts up revs high and won’t shut off with the key. Tracked down a wire that appears to be broken. After looking into it more there’s another wire not hooked up and they’re both coming from the ignition module. I will put pics below as well as a pic of the electrical schematics. I’m confused on where to go next. Thanks in advance.
Faztbullet
Blk/yell is the kill side and sounds like you lost ground to keyswitch. It is likely that wire is not used since its a 5 cylinder.
