1989 Force 125hp/20ft ARRIVA
Weekendr
I bought this boat a month ago. It set for 3 years and I did all of then necessary maintanance (changed hoses, drained/cleaned tank, new plugs, replaced power pack, new wiring from front to back,rebuilt carbs,etc.)
I've had the boat out several times since I bought it. I started it up this morning and a squeal came from the stator and metal shavings came from underneath. I shut the engine off and turned the stator by hand (compression is strong) to only hear a rubbing sound. I turned it couple of times and it seemed to go away but when I started it again it came right back with more shavings and a squeal.
Any idea what could be causing any of this to happen?
Cyclone
Re: 1989 Force 125hp/20ft ARRIVA
Sounds like something came loose or broke within the stator or trigger, Don't run it or turn it until you remove the flywheel for an inspection.
P.S. I have the same boat.
jerryjerry05
One of the stator bolts probably came loose.Remove the flywheel and see.J
Weekendr
Thanks guys. Will get back to you in a couple of days.
dieselguy
hey question for you since you have the same boat is it just a dog out of the hole do you think you could ski behind it?
