1989 force 125 trim
JDANIELSETLIFF
Hey i just purchased a trim pump last week and was wondering what type or what the best fluid to run in it and also how much so i meed to buy at a time thanks in advance
jerryjerry05
The factory used 30w. oil.
Some used trans fluid or power steering fluid or trim and tilt oil.
I use 30w
Make sure you flush the system once you install the new pump.
You can flush by loosening the front hyd. line.
Fill it and cycle it.
Loosen the line and cycle it.
Be careful as it can develop a lot of pressure and hurt you.
