1989 force 125 tirm and tilt ram
ckb93
I have a 89 force 125 the tilt ram where the line screws in broke....can the line screw in/band around the ram be replaced and if so where can I find the parts?
hall832
Re: 1989 force 125 tirm and tilt ram
send pics if you can
ckb93
Thank to both of you for responding. Commander, #7 looks like what I need.....will order tomorrow.....Thanks again
Jiggz
I replaced mine not too long ago. Although basically all I needed was just the female brass fitting where the tube fitting screws in. The band kit is just way too expensive but at the time was the only option I got. Come to find out you can actually find the same fitting at some hardware stores which costs a lot less. Just make sure if you decide to look just for the female fitting you take the old one with you. Otherwise you can just order the band kit.
RRitt
if dealer can not order, then you can make from 1" x 1/32 x 12" piece of stainless available from most local hardware stores
