tmcampbell
Thread starter- Joined
- Jun 25, 2003
- 17
the engine runs great however when i go to put it into gear it hangs. After some troubleshooting i have discovered the root of this problem but have questions about the solution. attached to the arm that advances the timing there is a fitting (for lack of a better word) its got a 90 degree bend and meets up with the linkage towards the lower unit, these two meet up and there is the resistance, i can take pics if it will help...i can manually put it in forward gear but cannot with the cables hooked up....any ideas?
