1989 FORCE 125 OUTBOARD
U68423
NEW TO OUTBOARDS CHANGED LOWER OIL, WHEN I TILTED MY MOTOR INT TRAILER POSITION NOTICED A LITTLE OIL MIXED WITH WATER DRIPPING DOWN, IS THIS NORMAL ? IT HAS NOW STOPPED.
roscoe
Re: 1989 FORCE 125 OUTBOARD
Dipping down from where?<br />What color was it?<br />If it was black, you are ok. This is normal exhaust residue.<br />If another color, get back to us with the details.
U68423
Water and oil mixed dripping out of the fresh water intake it only drips when in the full up position....
roscoe
Well, lower unit oil should be golden/clear, unless it is mixed with water, then it would be milky colored. I'd run it a few times, recheck the oil in the lower unit after each use. Probably nothing to worry about.
