shantyboat
Thread starter- Joined
- May 29, 2011
- 8
OK. I have an 89 125 HP with what appears to be an aftermarket remote control. (No makers name, but the various holes on the metal plate say "OMC" and "MERC" and so on.)
Questions:
Since the remote has a shift interlock, can I just remove the motor's manual interlock?
What the heck size nut is on the upper gear shaft?
Background: This remote is a two-stage control. Center neutral lock. Push forward or back to a detent to shift. Only beyond that point in fwd or rev can you advance the throttle.
I've replaced the control cables, which were stiff and probably 20 years old. They work great and the remote is smooth.
Engine stared right up and ran fine for several tests. But then the remote's shift function and the motor's "shift interlock" get out of synch.
As a result the arm on the towershaft is not fully retracted and the "interlock" plate presses above or below on it, causing a jam. I can manually reset the interlock by rotating the towershaft arm.
Paint scraping on the interlock plate shows this has been going on for a while, probably before I owned the boat.
I would adjust the interlock but it's almost impossible to get at.
Frankly, since the remote already has gearing that prevents whipping from forward to reverse at full throttle, I'd just like to take this interlock off. The service manual (page 129) and the parts diagram indicate this is something removable. The parts list neglects to give the size of the nuts.
Naturally it's barely accessible and I'm scouting for wrenches to take off the upper lock nut. The service manual makes the adjustment of the plate (up or down) seem real simple. It's not.
Advice, tips, whatnot !?
Questions:
