1989 evinrude outboard temp alarm.
rmhbass
Hi.
I recently purchased a boat that was sitting in a barn for a few years. The motor seems to run pretty good until I go to full throttle. After a few minutes the temp alarm goes off and the boat shuts down until it cools off. I was planning on installing a new impeller even though water is running through it. I was wondering what else may be causing the alarm to activate. I was told the motor does not have thermostat just a temp sensor. I'm new at boating and would appreciate any help.
Thanks.
Rob
iwombat
Re: 1989 evinrude outboard temp alarm.
What exactly are we working with here? I'm pretty sure that '89 - whatever has a t-stat.
rmhbass
sorry. I forgot to mention the motor is a 25hp evinrude.
Rob.
kskomro
I have a 1988 Johnson 25HP, almost the same motor. And I have the same problem today as you have. I took off the head to find a old rusted, not working thermostat. I will be off tommorw to buy a new one, along with new gaskets. My motor got so hot, it actually was smokeing and the wires were melting.
rmhbass
Thanks for the info. I replaced the impeller and the thermostat is next.
kskomro
UPDATE, I did not change thermostat, I was going flat out on lake, motor overheated and fried! I dis assembled to find part of the Theromostat lodged in the water passage, It blocked the water, and now is TOAST
WTL
Thats awful news. I'm really sorry to hear it.
I dont know whats going on, but I had the same problem - today - with my 1986 28 horse. Its peeing a little out of the top, not so much near the midsection - but it overheats after going full throttle and the alarm goes off - it smokes some too. I'm gonna check the stat tomorow - do I need to take off the cylinder head or is it just the water jacket?
