1989 evinrude banging
edson1988
Hi everyone my problem started a while ago with doing water pump and I got the shift rod length wrong so I fixed the shift rod length but the engine would bag as if I was hitting a log at 4000rpm so I bought a clutch dog thinking it could be slipping. I have the gear case open thinking that something was broken in there but teeth on gears are fine no chips or wear and clutch dog looks brand new . If someone has any ideas what else to look at while it's apart would be appreciated
jakedaawg
Better discription may help.
One big bang, several little ones, does engine jolt visibly?
edson1988
It would do 1 big bang then boat goes for a bit then will bang again was doing it around 4000 rpm
