1989 Evinrude 90HP - Maintenance after sitting for 3 years?
kcwf25496
I'll start by saying I am not an boating or automotive expert by any means. I have a 1990 Skeeter SD-80, with a 1989 Evinrude 90HP outboard. I had some type of electrical/grounding issue that was preventing the motor from starting and I did not have time to fool with it at the time, so I put it off. Fast forward 3 years and I am just now getting around to figuring out that issue, and the motor has been sitting without being used ever since then. Assuming I get the original electrical issue fixed, I know there must be a laundry list of other things I need to do before actually putting this motor back to use. I have looked up other info on the internet but I wanted to get some insight from people who may know more specifically about Evinrude's, just in case I miss something. If anyone could give me some things that I should check and/or change, or anything like that at all, that would be most appreciated. Even from the simplest thing, like I said I'm not an expert by any means so even if it's something you assume I will already know or do, I'd appreciate it if you went ahead and told me anyways. Thanks in advance.
Honorary Supreme Mariner
Post the numbers from a compression test first.------Is oil injection in service , yes or no ?------Needs a new impeller for proper cooling too.----If it sat with fuel in the carburetors they may require cleaning.
clemsonfor
Unless carbs were stored dry there probably full of crap. And if they were dry the gaskets maybe old and leak anyway. I would try to run it first with the plan to rebuild them all , if you don't have you look at it as a win and you lucked out.
I also would do a waterpump impellor. And just check and grass any steering fitting to make sure there not seized.
Drain the fuel tank and properly dispose of the fuel. Plugs are probably fine.
