fishinisfun
- Apr 18, 2012
- 1
Hello! 3 years ago, I purchased a 1989 16'9" stratos bass boat. It came with an Evinrude 60 hp vro outboard motor. Last time the boat was driven before me was 1991. the previous owner said that his wife died so he hurried off the lake and never ran it out of gas. that was the last time it was touched until i bought it in 2010. Since then, i had 3 marine engine mechanics go through the engine. ive had the carbs cleaned and re jetted, impeller replaced, a few seals replaced and had the whole motor gone over by all 3 mechanics. i heared that the oil injection sometimes failed, so i took it out and just started mixing my oil into the gas. i also had problems with water getting into my gas tank from the breathing tube, so i put a gas water separator. i then had problems with it starving for gas, so i put in an automotive fuel pump with a regulator.
The engine now seems to run great, but it just feels sluggish. im not sure if its because its a heavy boat with all my gear and such, but it takes quite a while to get on plane... with 2 people and the livewells filled, good luck getting on plane unless one person helps by moving to the front casting deck. I put a hydrofoil on the motor and that helped a little, but its still a huge problem. Here's the kicker, once i get on plane, my max speed is 28mph at 5200 rpms.
my prop is a 13 3/4 x 15 3 blade. i have friends 16 foot boats with 40hp motors that get out of the hole and have a top end speed faster than mine.
So basically, i have a poor hole shot, and poor top end but my rpms reach a decent 5200. does this mean that my boat is just too heavy? any help would be appreciated! thanks!
