PossumHead
Thread starter- Joined
- Feb 8, 2016
- 3
Started having problems with getting engine to start. I pulled each plug and grounded it, and was getting sporadic fire on at least one of the plugs, can't remember if it was more than one. Changed the power pack.
Then noticed fire jumping from the top coil to block. Changed out the coils.
Cleaned and rebuilt carbs with Sierra kit. Changed fuel pump diaphragm that was leaking.
Engine cranked and ran fine for maybe 20 hrs. Then it suddenly lost power and began running at about 1/2 - 2/3 power. I don't have a tach, that's my guess.
A friend who has been crawfishing and doing his own motor maintenance for 40 years suggested I take a look at the reeds. I had overheated the engine once and he thought that might have warped them. They were metal and I assume factory, but I don't know for sure. There was a good bit of daylight shining through all of them, so I bought a replacement set of B133 Boyesens, installed them properly, no light shining through, not overtightened, used blue Loctite on the screws.
I didn't change any of the jet sizes in the carbs. I set the one on the side that is adjustable to 1.5 turns out. Engine wouldn't crank, but did backfire when I quit cranking.
That led me to think timing was issue. I don't have a timing light. Flywheel is where it is supposed to be, key is still in place and good.
My son and I fooled with it, he turned in the idle timing screw while I cranked the starter, and we eventually got it running. It would crank and run fine with the throttle up and timing fully advanced, and by adjusting the timing gradually we got it to idle, but it was idling fast.
Tried to crank it again two days later and it wouldn't start.
I'm just about ready to buy a new engine, as this one has been rebuilt topside and lower side twice, the last time around 2005.
Any thoughts as to whether or not it's worth it to take it in and get the timing and carbs adjusted professionally, any suggestions on what I might try before giving up?
