1989 Evinrude 48 SPL paint project...
SoTxFisher
Just a project I was working on.... 1989 Evinrude 48 SPL.. had some bad paint issues... stripped most of the bad areas down, then sanded and sanded and sanded using different grits till smooth.. then a Krylon dark grey primer.. several coats, wet sanding in between... then the final several coats of Krylon Fusion in Silver Metallic.. came out better than I imagined.. not factory perfect.. but 1000x better than it was.. hopefully that paint stays on.. mainly the lower unit area.. we run in saltwater.. so we shall see in time...
Photos are not in any order I don't think.. but you can tell where I started, progressed and finally ended up... Evinrude marine decals are on the way!
