1989 Evinrude 15hp Shallow Water Drive
jaustinmoore
My 1989 Evinrude 15hp (model E15ECEC) has a latch that engages the shallow water drive. When I engage the latch by placing it in the "up" position and lift up the motor, the shallow water drive link sits on the trim bar. This allows me to run shallow.
This feature no longer functions correctly. After close examination and cross referencing a parts diagram, I noticed that my motor did not have a reverse lock rod spring (part #96). I figured this was problem and ordered the part. The part arrived, and I do not know where or how to install it. Can someone please help?
Also, I am not sold that this is causing the shallow drive to malfunction. Maybe the shallow water drive spring (part #94) is the problem? This spring seems to pull the shallow water drive link (part #93) toward the shaft towards the shaft, so it may not be the culprit since the shallow water drive link needs tension toward the transom.
In summary, I need help troubleshooting the shallow water drive. Any help is much appreciated. Below are pictures of my motor for your reference.
Latch Disengaged:
Latch Engaged:
