1989 evinrude 150xp fireing problem need help
alvin1982
89 evinrude fireing on1 out of 6 cylinders if someone has an idea i would be gratefull
emdsapmgr
Re: 1989 evinrude 150xp fireing problem need help
Unlikely the 6 coils are bad, but there are three expensive components which can contribute to this, the power pack, stator and timer base. The power pack is most suspect, but since they are all expensive, you may want to do some diagnosis first. A factory service manual will describe the test procedures and special instruments needed to check these three components. You can get one from the original publisher, Ken Cook Co., in Milwaukee. They are also on the web.
alvin1982
thanks for the help . i found the problem . it was a bad conection on the triger . thanks again .
